Apr 29, 2025 12:38 AM UTC
st-image-weston do_image_tar , the rootfs size 1038032(K) exceeds IMAGE_ROOTFS_MAXSIZE: 9326720(K)
I'm building st-image-weston on latest openstlinux scharthgap distribution package, and I got the error mentioned in Subject. All the fetch/compile/install are done, and the last step throw this error.
Where is the IMAGE_ROOTFS_MAXSIZE defined? I'd really don't want to override anything in conf/local.conf, the build took so much time.
Thanks.
frankcAuthor
Apr 29, 2025 12:40 AM UTC
BTW, I knew the reason why it grows a bit, that's because I added wpe-webkit related modules, size increase is expected.
May 2, 2025 3:26 PM UTC
This post has been escalated to the ST Online Support Team for additional assistance. We'll contact you directly.
