ZLiu.3
Mar 10, 2023 2:48 AM UTC
RGB LCD does not display
My rgb lcd screen does not display。
My board is based on the STM32MP153AAA3 design, using a separate power supply.
This is my schematic diagram
​0693W00000aIdJqQAK.pngThis is the timing of the LCD
​0693W00000aIdKZQA0.png This is the LCD device tree
​This is some panel-simple driver code
​0693W00000aIdKPQA0.pngHere are some boot logs
Looking forward to your response!
ZLiu.3
ZLiu.3Best answer
Mar 28, 2023 1:13 AM UTC
i have solved it.
The ltdc node has a problem:
&ltdc {
 pinctrl-names = "default", "sleep";
 status = "okay";
 pinctrl-0 = <&ltdc_pins_b>;
 pinctrl-1 = <&ltdc_pins_sleep_b>;
 port {
 #address-cells = <1>;
 #size-cells = <0>;
 ltdc_ep0_out: endpoint@0 {
 reg = <0>;
 remote-endpoint = <&rgb_8_panel_in>;
ZLiu.3
ZLiu.3AuthorBest answer
i have solved it.
&ltdc {
 status = "okay";
 port {
 #size-cells = <0>;
 reg = <0>;
