PatrickF
PatrickFBest answer
Sep 30, 2021 12:20 PM UTC
not tested, but have you tried to ensure duty_cycle is always smaller than period ?
I have tested TIM1 using pwm-leds like described here https://wiki.st.com/stm32mpu/wiki/TIM_device_tree_configuration#TIM_configured_in_PWM_mode
&timers1 {
	/* status = "okay"; */
	/* spare all DMA channels since they are not needed for PWM output */
	/delete-property/dmas;
	/delete-property/dma-names;
	/* define pwm1 label */
	pwm1: pwm {
		/* configure PWM pins on TIM1_CH1 */
		pinctrl-0 = ;
		pinctrl-1 = ;
		pinctrl-names = "default", "sleep";
		/* enable PWM on TIM1 */
		status = "okay";
		/* PWM DT user on TIM1_CH1: "pwm1", tim1_test with "pwm-leds" */
	pwmleds {
		compatible = "pwm-leds";
		tim1_test {
			label = "PWM-TEST";
			/* Use pwm1 channel 0 (e.g. TIM1_CH1) */
			/* period in nanoseconds (***), normal polarity (0) */
			pwms = ;
			max-brightness = ;
			default-trigger = "default-on";
So, not really similar to your case (here period is fixed in DT and I think cannot being changed using sysfs), but behind it is using same timer driver.
With brightness at 127 (50%), I end up to:
root@stm32mp1:~# echo 127 > /sys/class/leds/PWM-TEST/brightness
root@stm32mp1:~# cat /sys/kernel/debug/pwm
platform/44000000.timer:pwm, 4 PWM devices
 pwm-0 (tim1_test ): requested enabled period: 1197 ns duty: 596 ns polarity: normal
 pwm-1 ((null) ): period: 0 ns duty: 0 ns polarity: normal
 pwm-2 ((null) ): period: 0 ns duty: 0 ns polarity: normal
 pwm-3 ((null) ): period: 0 ns duty: 0 ns polarity: normal
Regards,
In order to give better visibility on the answered topics, please click on 'Best Answer' on the reply which solved your issue or answered your question.Tip of the day: Try Sidekick STM32 AI agent
PatrickF
PatrickFBest answer
&timers1 {
	pwm1: pwm {
		pinctrl-0 = ;
		pinctrl-1 = ;
		status = "okay";
	pwmleds {
		tim1_test {
			label = "PWM-TEST";
			pwms = ;
			max-brightness = ;
Regards,
