On STM32 CubeMX : FreeRTOS and Timebase Source not selectable ?
Hello dear ST community,
I try to test FreeRTOS on the STM32MP1 for the Cortex-M4 and I encounter a problem:
I've got the following warning: "When FreeRTOS is used, it is strongly recommended to use a HAL timebase source other than the Systick"
Ok, but when I try to select the systime base in the tab Pinout under SYS, the selection of TIM* is in light grey and so not available...
Is there any solution ?
Thank you!
Best regards,
Anthony
