SOCQU
Aug 27, 2026 2:31 PM UTC
NEGEDGE flag in DT
Dear ST team
Why does ST team add the “negedge” flag in DT  for the SDCARD timing initialization on ST eval DKs?
Sébastien
Erwan SZYMANSKI
Erwan SZYMANSKIBest answer
Aug 28, 2026 8:58 AM UTC
Hello ​@SOCQU ,
I think the NEGEDGE parameter was used in first driver implementation due to timing constraints on first designs using it. In normal conditions, this parameter should not have any impact on functional behavior, but can be necessary for very specific timing cases (you can refer to the Reference Manual to get more information on it).
Today, we could imagine removing it without any impact on the functional state.
By the way, this is mostly relevant on MMC DDR cases, and less important when we use DDR=0.
Kind regards,
Erwan.
Erwan SZYMANSKI
Hello ​@SOCQU ,
Kind regards,
Erwan.
SOCQU
SOCQUAuthor
Aug 31, 2026 7:40 AM UTC
Dear Erwan
Thanks for your answser. We defined our DT based on DK2 and it confirms it may not be needed as I’ve understood.
Sébastien
