Mar 12, 2024 11:40 AM UTC
Linux kernel Build Fails
i am using ubuntu 22.04 ltsScreenshot from 2024-03-12 16-53-58.pngThe above mentioned photo  is what was the output when i follow Readfile. How to do.txt;
i cannot able to figure out what was the issue.And because of this issue i am getting this issue isn't it?  (below attached)
Now this error evolved like this.
Gregory PLANCHON
Gregory PLANCHONBest answer
Mar 18, 2024 1:59 PM UTC
Did you source the SDK before compiling?
Regards,
Grégory
Gregory PLANCHON
Regards,
Grégory
Mar 19, 2024 7:13 AM UTC
yes,but first i did it wrongly. now i sourced the file and build kernel on same terminal(only changed directory based on your location). now issue shorted. thank you
