nataut
Jun 28, 2023 6:14 PM UTC
Linux image "/usr/local/" folder is empty
Hello everyone
The "bitbake <my_recipe>" process ends without errors but the "/usr/local/" folder of the image is empty (there are no ST demo folders and no "weston-start-at-startup" folder). Why?
nataut
natautBest answer
Jun 29, 2023 2:49 PM UTC
@Erwan SZYMANSKI
Thank you for your availability. I cleaned and rebuild the yocto image and now the "/usr/local" folders are present.
Many thanks
Erwan SZYMANSKI
Jun 28, 2023 9:59 PM UTC
Hi @nataut ,
What is the image you compiled ? Because here you tell me about a bitbake recipe compilation, but do you compile the complete image provided by ST ? Or did you make your own image ?
Whatever, you have to know that everything installed inside /usr/local in Yocto is overwritten by the userfs recipe.
To take an example, I invite you to take a look at /meta-st/meta-st-stm32mp/recipes-st/images/st-image-userfs.bb. I think it will help you to understand how to manage your userfs part with Yocto.
Kind regards,
Erwan.
nataut
natautAuthor
Jun 29, 2023 6:17 AM UTC
Hello @Erwan SZYMANSKI
I'm talking about a Yocto image with bsp openstlinux-4.19-thud. Until now those folders were always created. I haven't changed anything in the meta-st layer. In the last build I only changed my own device tree.What can be the reason? What should I check?
Many thanks
Erwan SZYMANSKI
Jun 29, 2023 6:50 AM UTC
Hello @nataut ,
ST does not support nor openstlinux-4.19 or openstlinux-5.4 anymore. I highly advice you to upgrade your OSTL version to 4.1 to get support.
Kind regards,
Erwan.
nataut
natautAuthor
Jun 29, 2023 9:14 AM UTC
It is difficult for me to update the openstlinux version.
I think my question is a general one that applies to the other versions as well.
Can anyone help me?
Erwan SZYMANSKI
Jun 29, 2023 10:49 AM UTC
@nataut ,
Do you build st-image-weston as your complete image ?
Kind regards,
Erwan.
nataut
natautAuthorBest answer
@Erwan SZYMANSKI
Many thanks
Erwan SZYMANSKI
Jun 29, 2023 3:35 PM UTC
@nataut ,
Thanks for your quick feedback.
Kind regards,
Erwan.
In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
