UVV
Jan 19, 2025 6:41 PM UTC
Kernel recipe hides upstream packages
Dear ST Team,
The kernel recipe in Scarthgap branch has following packaging:
FILES:${KERNEL_PACKAGE_NAME}-image += "boot/ ${KERNEL_IMAGEDEST}"
FILES:${KERNEL_PACKAGE_NAME}-imagebootfs = "boot/*.dtb boot/${KERNEL_IMAGETYPE}"
Which has following side effects.
  1. The base class in openembedded-core layer defines packaging in meta/classes-recipe/kernel.bbclass as follows
    FILES:${KERNEL_PACKAGE_NAME}-image = ""
    FILES:${KERNEL_PACKAGE_NAME}-dev = "/${KERNEL_IMAGEDEST}/System.map* /${KERNEL_IMAGEDEST}/Module.symvers* /${KERNEL_IMAGEDEST}/config* ${KERNEL_SRC_PATH} ${nonarch_base_libdir}/modules/${KERNEL_VERSION}/build"
    By placing everything from the "boot" directory into the image package you hide "dev" package completely and it becomes empty.
  2. The "imagebootfs" package repacks devicetrees, thus hiding kernel-devicetree package from openembedded-core layer. If you need custom package for any reason, I suggest you set run-time dependencies rather than re-arranging the files. FTR, devicetree packaging is done in meta/classes-recipe/kernel-devicetree.bbclass
    # recursivly search for devicetree files
    FILES:${KERNEL_PACKAGE_NAME}-devicetree = " \
    /${KERNEL_DTBDEST}/**/*.dtb \
    /${KERNEL_DTBDEST}/**/*.dtbo \
Could you please address these issues?
Thanks,
Vyacheslav
