Aug 21, 2025 3:16 AM UTC
How to generate a DDR templete for STM32DDRFW-UTIL
I am going to rebuild STM32DDRFW-UTIL Firmware to do DDR Test on my custom hardware. I looked at this document: https://github.com/STMicroelectronics/STM32DDRFW-UTIL/blob/main/README.md
in section 1.2.3.3 Customization, it mentions about using STM32CubeMX to generate the DDR Templete (stm32mp2xx-ddr4-2x16Gbits-2x16bits-template.h). Unfortunately, I tried the device tree generation function from STM32CubeMx; there was no DDR templete was generated. Is there any instruction to generate the DDR templete?
Pwxn
PwxnBest answer
Aug 22, 2025 1:24 AM UTC
Hello @ThinhNguyen
The file you mention can be found in the STM32DDRFW-UTIL source files:
https://github.com/STMicroelectronics/STM32DDRFW-UTIL/blob/main/DDR_Tool/STM32MP257F-DK/Inc/stm32mp2xx-ddr4-2x16Gbits-2x16bits-template.h
When you generate code with CubeMx, the DDR configuration is located in:
/Workspace/{Project Name}//CA35/DeviceTree/{Project Name}/tf-a/stm32mp25-mx.dtsi
(this is a path example)
I hope this will help you,
Regards.
Aug 21, 2025 3:53 AM UTC
You maybe using the wrong part of STM32CubeMX. You need to use the special DDR Configurator Tool to get a C Header file (.h file).
Aug 21, 2025 4:10 AM UTC
Hi @unknown,
I really can't find it. Can you take a screenshot for me?
Pwxn
PwxnBest answer
Hello @ThinhNguyen
Regards.
