Mark81
Feb 8, 2020 8:10 PM UTC
How to access to bootfs from Distribution Package
Using the Distribution Package for STM32MP1 I'm able to access to the rootfs partition, example:
my_postprocess_function() {
	cp -dr /home/osboxes/www ${IMAGE_ROOTFS}/opt/
	chown -R daemon:daemon ${IMAGE_ROOTFS}/opt/www/
But how to access to bootfs partition? For example to add the `boot.scr.uimg` or `rproc-m4-fw.elf`. I cannot find a `${IMAGE_BOOTFS}` variable.
Olivier GALLIEN
Olivier GALLIENBest answer
Feb 10, 2020 8:50 AM UTC
Hi @Mark81​
Please find attached a patch that suggest one solution to copy cube firmware exemples .elf inside bootfs.
Hope it can give you some insight for your need.
Olivier
Fee
Feb 10, 2020 6:29 AM UTC
Did you mount the bootfs (you can check that by using lsblk)? If not, try to mount the partiotion depending on your configuration. Then the access should be available via the rootfs.
Mark81
Mark81Author
Feb 10, 2020 6:43 AM UTC
Mounting the partition as devloop is the ugly workaround I'm actually using.
I'm asking how to do this within the Distribution Package (Yocto).
Olivier GALLIEN
Hi @Mark81​
Olivier
Mark81
Mark81Author
Feb 10, 2020 8:55 AM UTC
Yes, very useful! Thanks!
