Jean-Marc S
Jean-Marc SBest answer
Jan 19, 2023 7:24 AM UTC
Hello
I suppose you need to:
  • 1) Configure the LPTIM using CubeMx (duration of the periodic time,..)
  • 2) Activate the wakeup source for LPTIM
example provided here for UART4:
https://wiki.st.com/stm32mpu/wiki/Power_overview#Example_of_wakeup_source_activation
echo enabled > /sys/devices/platform/soc/40010000.serial/tty/ttySTM0/power/wakeup
echo enabled > /sys/devices/platform/soc/40010000.serial/power/wakeup
(LPTIM @ is 40009000)
 make sure the clock for LPTIM are activated during the sleep mode
(only some possible hint, I am not familiar with DT myself, hope it helps)
JM
Jean-Marc S
Hello
JM
