Senior
Oct 15, 2026 6:35 PM UTC
GStreamer - Play video works, but no sound?
Hi!
I’m using this comman
gst-launch-1.0 -v  filesrc location=bbb.mp4 !  qtdemux ! h264parse !  v4l2slh264dec !   waylandsink fullscreen=true
To play video in 1080p without lagging. But this comes without sound.
How can I play sound with gst-launch-1.0?
I can only play sound with “aplay /path/to/file.wav”.
WindowsAuthor
Senior
Oct 15, 2026 7:49 PM UTC
Here is one solution to play videos and sound at the same time e.g mp4 file. The question is now: Can this command to play videos with sound be shorten any further?
gst-launch-1.0 -e \
filesrc location=bbb.mp4 ! qtdemux name=d \
d.video_0 ! queue ! h264parse ! v4l2slh264dec ! waylandsink fullscreen=true \
d.audio_0 ! queue ! decodebin ! audioconvert ! \
audioresample ! audio/x-raw,rate=48000,channels=2,format=S16LE ! \
alsasink device=playback_hdmi
Jean-Christophe_TROTIN
Oct 16, 2026 6:54 AM UTC
As explained in https://wiki.st.com/stm32mpu/wiki/How_to_play_a_video_with_the_hardware_video_decoder, you can try to use the gst-play high level utility: the hardware-accelerated video decoder shall be automatically selected for its performances. With this utility, the command is obviously shorter, but the “control” on the different elements of the GStreamer pipeline is no more possible.
Otherwise, I don’t see how to remove any element of your GStreamer pipeline that looks good to me.
Hope this information helps.
Regards,
JC.
WindowsAuthor
Senior
Oct 16, 2026 8:01 AM UTC
Thank you ​@Jean-Christophe_TROTIN
I will try that within 3 hours and giving you a reply of the result.
