BVu
Jan 3, 2021 11:12 PM UTC
FreeRTOS task priority versus CMIS_RTOS v1
I'm using FreeRTOS v10.2.1, CMSIS RTOS v1
main.c (generated by CubeMX) has:
osThreadDef(defaultTask, StartDefaultTask, osPriorityNormal, 0, 128);
where osPriorityNormal is zero as defined in cmsis_os.h
I spawn all other tasks using the FreeRTOS xTaskCreate call where task priority is from 0..MAX_PRIORITIES-1. How does FreeRTOS task priority maps to CMSIS task priority if it maps at all? The reason i ask is that if i keep StartDefaultTask alive, how does it get scheduled against those tasks created with xTaskCreate?
BVu
BVuBest answer
Jan 4, 2021 7:51 PM UTC
The cmsis->FreeRTOS priority map is done in cmsis_os.c, makeFreeRtosPriority().
KnarfB
Jan 4, 2021 9:39 AM UTC
You may check the source code to find out.
BVu
BVuAuthorBest answer
