syedelec
Sep 25, 2023 2:20 PM UTC
EDMK information
Hello
I would like to understand the EDMK (Encryption Decryption Master Key). This key is used to decrypt and encrypt BL2 and FIP binaries.
Are there any other application of this key? For example, can it be used for LUKS ?
Is it possible to access some API to encrypt/decrypt using this key? Or is it reserved to the ROM code?
OlivierK
OlivierKBest answer
Oct 2, 2023 1:45 PM UTC
EDMK is mainly use for BL2 and FIP encryption/decryption (signingtool and romcode).
We use dm-encrypt, but not with EDMK (through HW RNG in OP-TEE). I don't know about LUKS.
EDMK is also used in the SSP process to encrypt/decrypt the secrets.
https://wiki.st.com/stm32mpu/wiki/How_to_deploy_SSP:_a_step-by-step_approach
It can be used elsewhere in a TA through OP-TEE for any AES processing. Upper OTPs could be made accessible through secure services but I don't know it it make sense to use the EDMK in this context.
https://github.com/linaro-swg/optee_examples
OlivierK
OlivierKBest answer
syedelec
syedelecAuthor
Oct 2, 2023 2:34 PM UTC
Thank you for your reply, we will stick to its main use (BL2 and FIP encryption/decryption).
I have managed to build an encrypted TF-A and FIP binary with EDMK and EDMK is in the OTPs. Moreover, my device is closed now.
However I can see that booting TF-A (or FIP) that are not encrypted but signed is working.
Is there a way to force encryption check?
syedelec
syedelecAuthor
Oct 13, 2023 9:36 AM UTC
Thanks for the details.
