Oct 15, 2024 3:34 PM UTC
Debug STM32MP1 M4 core with STM32CubeIDE
Hello
I am trying to debug M4 firmware on my custom STM32MP157C board.
I have a reference operating system built with yocto on which this works correctly.
I have to build system with a changed configuration and debugging of the same firmware is not working.
Of course I saw this video https://www.youtube.com/watch?v=YIhzzgJmop0
When I click the Debug button, the application correctly uploads however it won't start.
I get the message:
Error in final launch sequence:
Failed pre launch
Failed pre launch
Firmware remoteproc load failed, please:
1. make sure that /lib/firmware on your target has space
2. make sure that /lib/firmware has write access
Of course my target has space and write access - in other case file transfer will not be successful.
Starting the firmware manually works ok with this commands:
echo OpenAMP_raw_CM4.elf > /sys/class/remoteproc/remoteproc0/firmware
echo start >/sys/class/remoteproc/remoteproc0/state
Question: how to determine more precisely what failed?
Or maybe any hints what can I check?
Additionally in file ($HOME)/STM32CubeIDE/workspace_1.15.0/.metadata/.log I found:
!ENTRY org.eclipse.core.resources 4 368 2024-10-15 16:52:49.781
!MESSAGE Resource '/OpenAMP_raw' does not exist.
!STACK 0
java.lang.Exception: Resource '/OpenAMP_raw' does not exist.
at org.eclipse.core.internal.resources.ResourceException.provideStackTrace(ResourceException.java:42)
at org.eclipse.core.internal.resources.ResourceException.<init>(ResourceException.java:38)
at org.eclipse.core.internal.resources.Resource.checkExists(Resource.java:367)
at org.eclipse.core.internal.resources.Resource.checkAccessible(Resource.java:241)
at org.eclipse.core.internal.resources.Project.checkAccessible(Project.java:183)
at org.eclipse.core.internal.resources.Project.getDescription(Project.java:430)
at com.st.stm32cube.common.projectcreation.core.ProjectUtilities.hasProjectNature(ProjectUtilities.java:167)
at com.st.stm32cube.common.projectcreation.core.ProjectUtilities.hasProjectNature(ProjectUtilities.java:223)
at com.st.stm32cube.ide.mcu.analytics.core.MCUAnalyticsUtils.getRootProject(MCUAnalyticsUtils.java:176)
at com.st.stm32cube.ide.mcu.analytics.core.MCUAnalyticsRegister.send(MCUAnalyticsRegister.java:467)
at com.st.stm32cube.ide.mcu.analytics.core.MCUAnalyticsRegister.send(MCUAnalyticsRegister.java:350)
at com.st.stm32cube.ide.mcu.analytics.core.MCUAnalytics.lambda$1(MCUAnalytics.java:193)
at java.base/java.lang.Thread.run(Thread.java:833)
!ENTRY org.eclipse.cdt.dsf.gdb 4 5012 2024-10-15 16:52:55.974
!MESSAGE Error in final launch sequence:
Failed pre launch
!STACK 1
org.eclipse.core.runtime.CoreException: Failed pre launch
at org.eclipse.cdt.dsf.concurrent.Query.get(Query.java:112)
at org.eclipse.cdt.dsf.gdb.launching.GdbLaunchDelegate.launchDebugSession(GdbLaunchDelegate.java:252)
at org.eclipse.cdt.dsf.gdb.launching.GdbLaunchDelegate.launchDebugger(GdbLaunchDelegate.java:109)
at org.eclipse.cdt.dsf.gdb.launching.GdbLaunchDelegate.launch(GdbLaunchDelegate.java:97)
at com.st.stm32cube.ide.mcu.debug.launch.DSFDelegate.launch(DSFDelegate.java:336)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:805)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:716)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:1040)
at org.eclipse.debug.internal.ui.DebugUIPlugin$1.run(DebugUIPlugin.java:1243)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
Caused by: org.eclipse.core.runtime.CoreException: Firmware remoteproc load failed, please:
> you can open a Console View for this..
at com.st.stm32cube.ide.mpu.debug.launching.MPUPreLaunch.execute(MPUPreLaunch.java:140)
at com.st.stm32cube.ide.mcu.debug.launch.LaunchSequenceUtil.stepPreLaunch(LaunchSequenceUtil.java:88)
at com.st.stm32cube.ide.mcu.debug.launch.GDBExtendedJtagDSFFinalLaunchSequence_7_12.stepPreLaunch(GDBExtendedJtagDSFFinalLaunchSequence_7_12.java:94)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:568)
at org.eclipse.cdt.dsf.concurrent.ReflectionSequence$ReflectionStep.execute(ReflectionSequence.java:160)
at org.eclipse.cdt.dsf.concurrent.Sequence.executeStep(Sequence.java:475)
at org.eclipse.cdt.dsf.concurrent.Sequence$2.handleSuccess(Sequence.java:437)
at org.eclipse.cdt.dsf.concurrent.RequestMonitor.handleCompleted(RequestMonitor.java:391)
at org.eclipse.cdt.dsf.concurrent.RequestMonitor$2.run(RequestMonitor.java:317)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635)
!SUBENTRY 1 com.st.stm32cube.ide.mcu.debug.launch 4 0 2024-10-15 16:52:55.974
!MESSAGE Failed pre launch
!STACK 1
!SUBENTRY 2 com.st.stm32cube.ide.mpu.debug 4 0 2024-10-15 16:52:55.974
!MESSAGE Firmware remoteproc load failed, please:
SLasn.1
SLasn.1Best answer
Mar 7, 2025 9:13 AM UTC
Not that I know anything, but when debugging in production mode (A7 is running), I have seen this error which was solved by changing the SSH connection properties.
In Window -> Preferences -> Remote Development -> Remote Connections
Min was set to Public key auth, I set it to Password based. And since my A7 does not have /bin/bash, I also had to change in Advanced -> Login shell command (changed to /bin/sh).
PatrickF
Oct 15, 2024 3:40 PM UTC
Hi @Pawel85 ,
latest ecosystem related information might be found in https://wiki.st.com/stm32mpu/wiki/Getting_started/STM32MP1_boards/STM32MP157x-EV1/Develop_on_Arm%C2%AE_Cortex%C2%AE-M4
Hope this help.
Regards.
In order to give better visibility on the answered topics, please click on 'Best Answer' on the reply which solved your issue or answered your question.Tip of the day: Try Sidekick STM32 AI agent
Pawel85Author
Oct 15, 2024 6:56 PM UTC
Hi
Thank you for answer, but unfortunately I don’t find any new information in suggested link.
I will try to better explain.
I have one version of M4 firmware and one hardware platform, but two version of operating systems. One first system all works perfectly, on second system debug won’t start.
Based on this I suppose STM32CubeIDE and M4 firmware is configured properly.
The problem is with operating system. SSH, serial console, file transfer, M4 firmware starting - all is working ok. And at this moment I don’t have any clue where the problem could be.
Is any method to retrieve more detailed log about STMCube32IDE operation (debug launching)?
SLasn.1
SLasn.1Best answer
