nataut
Jul 16, 2023 5:53 PM UTC
Black screen using QML code to play a video
Hi all.
I'm developing a QT/QML application for my embedded openSTLinux project. This application has to play some videos with relative audio. I'm trying to play a mp4 file. If I use the following
gst-launch-1.0 playbin uri=file:///home/root/media/my_video.mp4 video-sink="waylandsink sync=false"
audio and video are played correctly. Instead, if I use QML code, for example this
Item {
 visible: true
 width: 1024
 height: 600
 Video {
 anchors.fill: parent
 source: "file:///home/root/media/my_video.mp4"
 autoPlay: true
 focus: true
or this
Item {
 visible: true
 width: 1024
 height: 600
 MediaPlayer {
 autoPlay: true
 VideoOutput {
 source: mdpExample
the display shows nothing (black screen) but the audio is played correctly.
Below the "gstreamer" plugins I have installed in my openSTLinux image
gstreamer1.0 \
gstreamer1.0-plugins-good \
gstreamer1.0-plugins-base \
gstreamer1.0-plugins-bad \
gstreamer1.0-plugins-ugly \
gstreamer1.0-rtsp-server \
gstreamer1.0-omx \
gstreamer1.0-libav \
gstreamer1.0-dev \
gst-validate \
gst-examples \
How can I solve the problem?
Erwan SZYMANSKI
Jul 17, 2023 6:52 AM UTC
Hello @nataut ,
I think your issue is related to the way you code your QML app to play the video.
I made a such kind of demonstration, and please see below the way I use Video Player:
 MediaPlayer {
 source: "gst-pipeline: filesrc location=/home/weston/database/videos/" + video_src + " ! avidemux ! jpegdec ! qtvideosink"
 autoLoad: false
 autoPlay: false
 loops: MediaPlayer.Infinite
 // loops: 1 /* Play only once */
 VideoOutput {
 width : videoPlayer.width
 height : videoPlayer.height * 0.8
 opacity: 0.9
 anchors.top: parent.top
 source: mediaPlayerVideos
 focus: true
 visible: true
Of course, you will have to adapt the Gstreamer pipeline to your case, but what is important is to also use the "qtvideosink" at the end, to well integrate the video inside your Qt UI.
Please try to get inspire by this example and tell me your feedback if you can.
Kind regards,
Erwan.
nataut
natautAuthor
Oct 20, 2023 12:42 PM UTC
Hello @Erwan SZYMANSKI ,
I'm sorry but I only noticed your response today
I tried your suggestion. I used the following pipelines
"gst-pipeline: filesrc location=/home/root/media/video_test.avi ! avidemux ! jpegdec ! qtvideosink"
"gst-pipeline: filesrc location=/home/root/media/video_test.avi ! decodebin name=dec ! videoconvert ! qtvideosink"
"gst-pipeline: filesrc location=/home/root/media/video_test.avi ! decodebin name=dec ! videoconvert ! waylandsink"
"gst-pipeline: filesrc location=/home/root/media/video_test.mp4 ! avidemux ! jpegdec ! qtvideosink"
"gst-pipeline: filesrc location=/home/root/media/video_test.mp4 ! decodebin name=dec ! videoconvert ! qtvideosink"
"gst-pipeline: filesrc location=/home/root/media/video_test.mp4 ! decodebin name=dec ! videoconvert ! waylandsink"
but I have always the following error
Error: "No URI handler implemented for \"gst-pipeline\"."
Best regards
Erwan SZYMANSKI
Oct 20, 2023 12:49 PM UTC
Hello @nataut ,
No problem for the delay, we know we had a little issue with mail notification and we apologize for that :)
Hmm I see. Which version of QtMultimedia do you import in your QML code ? In mine where things are working fine, I have followings imports :
import QtQuick 2.9
import QtQuick.Window 2.9
import QtQuick.Controls 2.9
import QtMultimedia 5.11
import QtQuick.Controls 1.4 as QQC1
import QtQuick.Controls.Styles 1.4
If it changes nothing, can you tell me which OpenSTLinux do you use, and how did you generate your main SW image (Yocto, Starter image ?).
Rgs,
Erwan.
