Senior
Mar 24, 2025 2:29 AM UTC
X-Cube-Matter cannot be compiled with MDK Arm
I am developing using X-Cube-Matter v1.4.0.
I imported the BLE_Ota project onto MDK Arm and built it, but the following error occurred and I was unable to compile it.
../Core/Src/app_entry.c(28): warning: In file included from...
../STM32_WPAN/app\app_thread.h(30): error: 'stm32wbxx_core_interface_def.h' file not found
30 | #include "stm32wbxx_core_interface_def.h"
Please tell me the cause.
STTwo-32
STTwo-32Best answer
Apr 16, 2025 8:36 AM UTC
Hello @AkihiroN
BLE_OTA app is part of X-Cube-Matter OTA sample with SBSFU and Matter SDK. It has been built under CubeIDE. It may be just porting issue. Could you please test it using CubeIDE. And as a recommendation, it is better to use the last version of the STM32CubeIDE for any use case on the X-Cube-Matter.
Best Regards.
STTwo-32
STTwo-32
Apr 14, 2025 5:10 PM UTC
Hello @AkihiroN
I've escalated this behavior internally to be checked (under internal ticket number 207666). I will be back to you ASAP.
Best Regards.
STTwo-32
STTwo-32
STTwo-32Best answer
Hello @AkihiroN
Best Regards.
STTwo-32
AkihiroNAuthor
Senior
Apr 16, 2025 8:46 AM UTC
Hello @STTwo-32
Thank you for your confirmation. I understand.
However, if possible in the next update, I would appreciate it if you could consider making it compatible with Keil MDK Arm as well.
Best Regards.
STTwo-32
Apr 16, 2025 8:50 AM UTC
I will escalate your request to review this possibility.
Best Regards.
STTwo-32
