Sep 7, 2023 1:44 PM UTC
Writing characteristic fails with bad parameter
Hello all,
Working on communication between two STM32WB55 boards , one configured as client , and one as server.
When trying to write a characteristic I get a bad parameter error, but when I use the write characteristic long command it works fine.
Writing a small amount of bytes works on both commands.
MTU discussed: 0xFB > size of write ( 0x5E).
What can be the issue?
Thanks!
Issamos
IssamosBest answer
Sep 7, 2023 2:15 PM UTC
Hello @jimmy11
Are you sure of this information:
  • MTU discussed: 0xFB
Best regards .
II
Issamos
IssamosBest answer
Hello @jimmy11
Best regards .
II
jimmy11Author
Sep 11, 2023 12:57 PM UTC
Thanks, when I used the the MTU exchange command it solved the issue
Issamos
Sep 11, 2023 1:22 PM UTC
Happy to now that you're problem has been solved.
Please close the topic by choosing a best answer.
Best regards.
II
