Pierre Castera
Sep 15, 2022 12:05 PM UTC
Why STM32WB15CC as a GATT server is not detected in ST BLE Toolbox after following "STM32WB Getting Started : Part 12b, Lab. Receiving data from the phone" video
I try to create a GATT server with a NUCLEO-WB15CC.
I'm a beginner with STM32WB MCUs so I followed the Getting Started Series video and particulary : "STM32WB Getting Started Series: Part 12b, Lab. Receiving data from the phone"
When its came time to test the firmware my device was not detected in ST BLE ToolBox mobile App
I tried to upgrade the BLE stack Firmware with "stm32wb5x_BLE_Stack_full_fw.bin" but nothing changed.
Then I tried the example Firmware BLE_p2pServer and it's work.
It's seems to be a problem links to STM32WB15. Indeed in the video they used a STM32WB55 and in the comment of the video other persons has the same problem when using a STM32WB15.
Does anybody had this problem and knows how to fix it?
Thank you
Remy ISSALYS
Remy ISSALYSBest answer
Sep 16, 2022 10:35 AM UTC
In order to use BLE Custom template for WB15, you have to tune some parameters to fit with the RAM size for the GATT database. So, you have to change the following parameters:
  • CFG_BLE_ATT_VALUE_ARRAY_SIZE = 1290
  • CFG_BLE_NUM_GATT_ATTRIBUTES = 30
  • CFG_BLE_NUM_GATT_SERVICES = 4
Best Regards
Remy ISSALYS
Best Regards
Shahin
Nov 28, 2022 12:28 PM UTC
Which file do I need to edit to change this? @Remy ISSALYS​
Shahin
Nov 28, 2022 2:01 PM UTC
Don't worry found it in app_conf.h, Unable to delete post
Pierre Castera
Sep 19, 2022 6:39 AM UTC
It's works
Thank you very much
Best regards
ICMosquera
Jan 9, 2023 6:56 AM UTC
Do you also have a tuning for STM32WB55CC MCUs? I also followed this YT Tutorial for my Custom STM32WB Board.
Shahin
Jan 9, 2023 8:48 AM UTC
Tuning what exactly?
Here is a link for Tuning the HSE which could be relevant - https://www.youtube.com/watch?v=qNJR9vL1D0c&ab_channel=STMicroelectronics
Oct 8, 2023 1:31 PM UTC
okay i solved it by upgrading the FUS according to STM32WB Getting Started Series: Part 9, STM32WB FUS update
