Why does in the BL072Z led LD5 keeps in green color?
Hi, in the datasheet of the BL072Z board says: (pag 17)
"LD5 = Green when communication "
But when I connect the board with the UART port to program and see the data in the terminal the LD5 is in red color and everything works ok, but then the LD5 sometimes turn on green and the node stop working, I had to reconnect it to restart the Tx, why?
thanks
