Where to find Lora header in packet?
Hi
Im using the SUBGHz in Lora mode for communication with point to point. What I want to do is design low power communication. I plan to send the first packets from the battery node to SF12 , then the permenant connection node will detect the signal strength , then the battery node will adjust the SF value to make the battery last longer.
I assume the receiving node must be able to detect what the sending SF value is, as when I program the node for TTN, the packet received detects the SF factor. Anyone know the SUBGHz command for detecting the SF valulue?
Many Thanks
Scott
