CBuch.1
May 24, 2022 8:24 AM UTC
What does the RCC Option RF Wakeup?
I can not find an Resource that describes the funktion of the RF Wakeup.
Im using an STM32Wb5m, so a dual-core with Application and Network core. In my understanding the "RF Wakeup" is used to wakeup the network core if an signal is coming from the radio - but im not using any Power management options, so the network core should run always and should not need any wakeup.
What am I missing or for what is the "RF Wakeup" clock necessary?
I configure it in my example to use the BLE radio. Without this RCC Config the radio does not work.
 RCC_PeriphCLKInitTypeDef PeriphClkInitStruct = {0};
 PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_RFWAKEUP;
 PeriphClkInitStruct.RFWakeUpClockSelection = RCC_RFWKPCLKSOURCE_LSE;
 if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct) != HAL_OK)
 ret = UTILS_ERR;
Remy ISSALYS
Remy ISSALYSBest answer
May 25, 2022 8:51 AM UTC
The "RF Wakeup" clock is necessary because CPU2 always uses power management for radio even if CPU1 doesn't use low power mode.
Best Regards
Remy ISSALYS
Best Regards
