NMosk.1
Aug 30, 2020 7:03 AM UTC
We are trying to develop a low-cost solution for communication between 1 master and 2 slave devices, and to this extent we want to use the SPBTLE-1s chip. How can we generate a working project for this chip in cubeIDE?
We want to program only this chip directly. NOT an evaluation board, or one of the STM32WB series.
EJOHA
Sep 2, 2020 10:45 AM UTC
Hi NMosk.1
Unfortuanately STM32CubeIDE does not support the SPBTLE-1s or BlueNRG-1 system-on-chip.
It is possible to use STM32CubeIDE to develop the application and build it but it will not work for debugging on target.
To use STM32CubeIDE for development you will need to create a project for a similar Cortex-M device and configure the linker script file according to your device.
Have you tried using ST-LINK utiilty for programming the device? More info here.
NMosk.1
NMosk.1Author
Sep 3, 2020 2:40 PM UTC
Thank you for your answer. We were indeed able to rig the project files of a different device for use with the aforementioned chip.
