JDIRI.1
Feb 1, 2023 6:08 AM UTC
Wb55 - How to read values from ADC
Hi everybody!
Working on Martian Robot développed by VittaScience​, I need to read values coming from 5 blackline sensors to the ADC of the wb55.
I tried to analogRead() the pin but nothing...
Some ideas?
Thanks!​
Jaroslav JANOS
Jaroslav JANOSBest answer
Feb 2, 2023 2:59 PM UTC
Just tested on 500Kbit/s, works fine for me. Please check the wiring and SPI configuration: master mode, full duplex, datasize 10 bit and enabled NSS signal on PA4.
JDIRI.1
JDIRI.1Author
Feb 3, 2023 7:23 AM UTC
Hi @Jaroslav JANOS​ ,
It works fine, thank you very mutch, I missed NSS Signal on my configuration.
Now I isolate all the values for each sensor but the values seems to fluctuate a lot with the light .
Just need to find an algorithm to detect the lines now...
Thank you!
