Using EVAL-ADXL1002Z (single-axis analog accelerometer) with NUCLEO-WL55JC1 development board
Good afternoon everybody,
I would like to determine acceleration values (in micro g's) by means of the EVAL-ADXL1002Z (analog single-axis accelerometer) evaluation board and the NUCLEO- WL55JC1 development board. Once this is done, I would like to transmit this data to TTN (The Things Network) network server. I should mention that I already have my own LoRaWAN network working correctly after following the LoRaWAN_End_Node example.
I would really appreciate any help or example given to carry out these two tasks.
Thank you for your time,
Carlos
