Aug 21, 2025 2:40 AM UTC
Using acceleration sensor at LoRa communication.
I am using NUCLEO-WL55JC1 to use LoRa communication.
And I add acceleration sensor of LSM6DSOX to this board and I want to get  acceleration data while communicating LoRa.
But I could not get correct acceleration value.
And I could get correct acceleration value when I comment out  MX_LoRaWAN_Process() in main.c.
So It seems that acceleration sensor doesn't work when LoRa is enable.
Do you know why and could you give me advices of this issue.
STTwo-32
STTwo-32Best answer
Sep 22, 2025 3:25 PM UTC
Hello @machi
The sensor may work fine with the LoRaWAN implementation. But you should create a task on the sequencer that work on the data acquisition. You may refer to this Playlist tutorial that do the same process you are trying to implement using the NUCLEO-WL55JC1 and the X-NUCLEO-IKS01A2.
Best Regards.
STTwo-32
Andrew Neil
Aug 22, 2025 11:29 AM UTC
Welcome to the forum.
You will need to give a lot more detail for anyone to be able to help  - please see: How to write your question to maximize your chances to find a solution.
So look into what changes when you have the LoRaWAN enabled.
What, exactly, does "doesn't work" mean here?
  • Do you lose all comms with the sensor?
  • Do you get corrupted data?
  • Is it just your calculations that go wrong?
  • other...?
Some general debugging tips here:
https://community.st.com/t5/community-guidelines/how-to-write-your-question-to-maximize-your-chances-to-find-a/tac-p/706966/highlight/true#M49
STTwo-32
STTwo-32Best answer
Hello @machi
Best Regards.
STTwo-32
