Dec 11, 2025 8:32 AM UTC
Unable to connect my stm32wle5jc to my stm32cube programming
Actually i tried to upload a custom frimware as per tutorial given in the Lora e5 mini documentation everything is going fine but when it came to changing the RDP level from BB to AA in the post i just changed the level fro BB to AA and clicked apply after changes the module got disconnected and that is the first and last time my board connected to my cube programmer after that i can't connect my lora e5 mini to my cube
i tried every method by under reset option and one thing i cannot access the boot0 pin in this board so i cant try this method
if any one faced this problem and solved it can you give me solution for this problem
