irmakci
Sep 23, 2011 11:45 PM UTC
UM0794: GSM interface
Posted on September 24, 2011 at 01:45
I read previous threads about source code. But how can i find source code related with UM0794: GSM interface?... Is there any link ? Should we contact local distributor for this? if it is so, why ?
Thanks in advance
Best Regards
#gsm-stm32 #unavailable-resources #unavailable-resources #unavailable-resources #unavailable-resources
    trevor23
    Sep 24, 2011 8:40 AM UTC
    Posted on September 24, 2011 at 10:40
    Well a quick google of UM0794: GSM interface leads to this
    http://www.stmicroelectronics.com.cn/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/USER_MANUAL/CD00248834.pdf
    Andrew Neil
    Sep 24, 2011 8:41 AM UTC
    Posted on September 24, 2011 at 10:41
    ''I read previous threads about source code.''
    You mean these:
    https://my.st.com/public/STe2ecommunities/mcu/Tags.aspx?tags=unavailable
    resources
    ''Is there any link?''
    As discussed in those threads - apparently not!
    ''Should we contact local distributor for this?''
    As discussed in those threads - apparently yes!
    ''if it is so, why ?''
    Thatremains a complete mystery!
    What on earth are ST playing at here?
    Edit
    : Sorry, the link above doesn't work - try:
    http://bit.ly/rl8dho
    Andrew Neil
    Sep 24, 2011 8:45 AM UTC
    Posted on September 24, 2011 at 10:45
    ''Well a quick google of UM0794: GSM interface leads to this
    http://www.stmicroelectronics.com.cn/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/USER_MANUAL/CD00248834.pdf'';
    But that's not the code - is it?
    That's just a PDF document!
    It tells you that code exists but gives no information on how to obtain it!
    Andrew Neil
    Sep 24, 2011 5:02 PM UTC
    Posted on September 24, 2011 at 19:02
    Beats me!
    Perhaps you should ask here:
    /b2dac913
    contact23
    Apr 4, 2014 9:21 AM UTC
    Posted on April 04, 2014 at 11:21
    Could you able to find the source code for GSM Library for STM32 ?
    If so could you please share it ?
    Thank you in advance
    Regards,
    Praveen
    Amel NASRI
    May 22, 2014 4:14 PM UTC
    Posted on May 22, 2014 at 18:14
    Please contact your distributor/FAE to get the firmware. The PDF file is available
    http://www.st.com/st-web-ui/static/active/en/resource/technical/document/user_manual/CD00248834.pdf
    -Mayla-
    Andrew Neil
    May 22, 2014 6:48 PM UTC
    Posted on May 22, 2014 at 20:48
    ''Please contact your distributor/FAE to get the firmware''
    So how about answering the question:
    WHY??
