Jun 10, 2024 9:15 AM UTC
UART reception isssue
Hello everyone,
I am working with a STM32WB5MMDK. I want to use the USART to print a message on Tera Term but i just have inversed triangles instead of "Hello world". I checked and both Tera Term and USART1 have the same parameters (baud rate, etc). I find it weird that i have a succession of triangles, and the other subjects related don't mention that.
Does anyone know how to fix this ?
Thank you
jumman_JHINGA
Senior III
Jun 10, 2024 3:19 PM UTC
Teala's point also considerable.. if you're having onboaard TTL to RS32 converter IC you have to use RS32 only ... if you're board is not having TTL to R232 coverter then you should use USB to UART bridge coverter ... otherwise you'll face garbage data issues
NourAuthor
Jun 11, 2024 2:09 PM UTC
Thank you for your help, i will try your ideas!
