BT.1
Feb 20, 2020 5:10 AM UTC
Tx Timeout on LoRa
I have made a custom PCB with the Murata CMWX1ZZABZ-091 module. When I try running the LoRa End Node or PingPong example (for LoRa Discovery kit B-L072Z-LRWAN1) , I get "Tx Timeout" on UART. The GPIOs and UART are working fine. How do I solve this?
BT.1
BT.1Best answer
Feb 25, 2020 11:18 AM UTC
Solved. The clock source power (VDD- TCXO ) had not been given in the PCB. That was why SPI and LoRa was not functioning
BT.1
BT.1AuthorBest answer
