Target is not responding, retrying...
I'trying STN32WLcube firmware 1.1.0. The LoRaWAN End Node works as aspected and now I need to add my sensors, but when I debug it I have the error "Target is not responding, retrying..."
DEBUGGER_ENABLED value is set to 1 ( I think is the same as DEBUGGER_ON on FW 1.0.0).
Any suggestion on how to work around this behavior?
Grazie
F.
