Guy Dillen
Feb 24, 2017 12:40 PM UTC
Sub 1GHz or other connectivity
Posted on February 24, 2017 at 13:40
For a new IoT proof-of-concept (PoC) I shortly start I need to measure some parameters like e.g. temperature in a building environment (building can be broad interpreted: an office building, a hospital, etc.). After some investigation I think an option would be using Sub 1GHz for connectivity.
My questions:
- Would indeed Sub 1GHz be a viable option for these kinds of use cases?
- Or, are there better alternatives?
- For our PoC what devkits/components (a few edge device kits + a gateway device to connect the edge devices to the Internet/CLoud), as a result of my 2 previous questions, can we best use?
Thanks.
#sub-1ghz-nucleo #stm32 #nucleo #wireless
    David SIORPAES
    David SIORPAESBest answer
    Feb 24, 2017 2:45 PM UTC
    Posted on February 24, 2017 at 15:45
    There's a very nice IoT kit based on ST Sub 1GHz SPIRIT radio that may well suit your needs: look at
    http://www.st.com/en/evaluation-tools/steval-idi005v1.html
     evaluation board. It's a coin-cell battery operated wireless sensor with MEMS accelerometer, temperature sensor and humidity sensor. You'd use a few of these boards as 'edge devices' and
    http://www.st.com/en/evaluation-tools/steval-sp1ml868.html
     as a gateway.
    Oliver Beirne
    Feb 24, 2017 1:57 PM UTC
    Posted on February 24, 2017 at 14:57
    Hello
    I have moved your question to the
    https://community.st.com/community/stm32-community/stm32-forum?sr=search&searchId=5d9c3d04-1155-4fa8-9db2-0ec0b76548e6&searchIndex=0
    ‌ where someone should be able to help you.
    Oli
    Guy Dillen
    Feb 24, 2017 4:34 PM UTC
    Posted on February 24, 2017 at 16:34
    Ok thanks.
    Guy
    David SIORPAES
     as a gateway.
    Guy Dillen
    Many thanks.
