Oct 28, 2026 12:41 AM UTC
STM32WLE5CCU6 – RF Output Impedance at 923 MHz, +22 dBm (UFQFPN48)
Hello ST Community,
I am designing an RF matching network for the STM32WLE5CCU6 (UFQFPN48) at 923 MHz, +22 dBm.
In AN5457, I found PA output impedance data for 915 MHz (+22 dBm, UFQFPN48), but not for 923 MHz.
I would like to ask:
  1. What is the recommended optimal PA load impedance at 923 MHz, +22 dBm for UFQFPN48?
  2. Can I use the 915 MHz impedance values for designing the 923 MHz matching network?
  3. Does ST provide reference matching component values for this configuration?
Thank you for your support!
Imen.DBest answer
Nov 6, 2026 2:01 PM UTC
Hi ​@vutranquoc
After an internal check, we do not have the impedance value at 923 MHz.
You can use the impedance value at 915 MHz as a starting point.
Nov 5, 2026 2:57 PM UTC
Hello ​@vutranquoc ,
Let me first welcome you to the ST Community.
Are you using an RF switch to separate the TX and RX paths, or are they working in a direct-tie configuration?
Nov 6, 2026 3:39 AM UTC
Hello Imen,
Thank you for your response.
I am using an RF switch to separate the TX and RX paths, with independent matching networks for each path.
My design operates at 923 MHz with a TX output power of +22 dBm.
Could you please confirm the recommended optimal PA load impedance at 923 MHz for the STM32WLE5CCU6 (UFQFPN48)?
Also, would it be acceptable to use the 915 MHz impedance values provided in AN5457 as a starting point, or does ST recommend different matching component values for 923 MHz?
Imen.DBest answer
Hi ​@vutranquoc
