Jun 30, 2026 12:07 PM UTC
STM32WLE5CCU6 FCC Frequency Hopping
I hope all is well.
I’m also looking for the FCC test report for the STM32WLE5CCU6. I noticed someone else had requested it previously, but the inquiry seemed to be redirected and may not have been followed through. In short, I will need someone from your compliance or technical team to contact me directly via email.
We are currently working on the FCC frequency‑hopping requirements, and I’d like to understand how this was handled on your side and hopefully obtain some manufacturer guidance. Thank you in advance.
Issamos
IssamosBest answer
Jul 1, 2026 11:36 PM UTC
@g9413015  ST run this community. But it is not a direct support (one to one) channel. It is an open Community where everyone is able to access and contribute to all cases (users and ST employees). So, if you are looking for someone from ST technical team to contact you directly. OLS should do the job.
II
Issamos
Jul 1, 2026 1:02 PM UTC
Hello ​@g9413015
For such request, I suggest you contact ST’s local Sales and marketing team or one of ST FAEs. You can also submit a direct support request on The ST online Support platform.
Best Regards.
II
g9413015Author
Jul 1, 2026 9:15 PM UTC
Hi ​@Issamos
Many thanks for getting back to me. I don’t understand why Sales would be involved in addressing technical questions about your products. I’m really hoping for straightforward communication rather than going through unnecessary cycles. I thank you in advance. Cheers.
Issamos
Jul 1, 2026 9:21 PM UTC
Hello ​@g9413015
First, I’m not representing ST here. I’m a Community member and not an ST employee.
For the recommandation, some of the internal information may need a one to one discussion with ST. For such kind of discussion (that may require an NDA or something), you should use a privet channel and not the community. That’s why I’ve suggested OLS.
Best Regards.
II
Andrew Neil
Jul 1, 2026 1:11 PM UTC
As ​@Issamos said, you probably need to contact ST direct for this.
You can find your local Sales Office here: https://www.st.com/content/st_com/en/contact-us.html
g9413015Author
Jul 1, 2026 9:07 PM UTC
Hi Andrew,
Many thanks for getting back to me. I’m a bit confused — why is Sales handling this technical question? It is the ST chip set we are talking about here. Many thanks. Cheers.
Andrew Neil
Jul 2, 2026 8:46 AM UTC
It’s not really a technical question, is it ?
You’re asking for regulatory documentation - which is not something that this community forum has access to.
