STM32WLE5CCU6 at 1.8V – RFO_LP output drops above the +12 dBm setting at 868 MHz
Hi everyone,
I’m working on a custom 868 MHz LoRa board for my SmartFarm project using the STM32WLE5CCU6. In a spectrum-analyzer sweep, the +12 dBm setting gave the highest measured level. Both the +13 dBm and +14 dBm settings gave a lower reading. I’m trying to determine whether this is related to the PA configuration, the PA supply during TX, or the impedance presented by my matching network.
Hardware and radio configuration
  • Supply: VDD and VDDRF share a nominal 1.8 V rail. VDDPA is also connected directly to that rail. VFBSMPS feeds VDDRF1V55 separately.
  • RF path: RFO_LP at 868 MHz, with a discrete matching network and an RF switch.
  • PA configuration: Set_PaConfig(0x05, 0x00, 0x01, 0x01), with a 10 µs TX ramp.
  • Normal LoRa settings: SF10, 62.5 kHz bandwidth, coding rate 4/7, 12-symbol preamble.
  • Regulator configuration: The firmware enters Standby HSE32 before calling Set_RegulatorMode(0x01) and writes SUBGHZ_REGDRVCR = 0x0B. HSE32 uses a crystal. The driver makes no explicit write to SUBGHZ_PAOCPR (0x08E7). Readback after PA configuration: [value or pending].
Spectrum-analyzer measurements
Programmed power Set_TxParams.Power Measured level, PaDutyCycle = 0x05
+12 dBm 0x0C 9.5 dBm real output, highest in this sweep
+13 dBm 0x0D 8.5 dBm
+14 dBm 0x0E 6.5 dBm, below the +12 dBm setting
Is there any reason, why the signal power decreases after 12 dBm?
Thank you in advance for the help,
Manuel
