Oct 27, 2024 8:33 AM UTC
STM32WLE5 subGhz Frequency offset vs supply voltage drop
Hi ,
In table 32 in the Datasheet we can see TXDRP parameter which describes RF output power drop versus supply voltage.
is there also RF frequency offset as a result of the supply voltage drop ? If the answer is yes - can you estimate it ?
Thank you,
Viola
Uwe Bonnes
Chief
Oct 27, 2024 5:20 PM UTC
What is yoyr RF frequency source? How large is the frequency chance vs supply voltage.
violaAuthor
Oct 28, 2024 6:32 AM UTC
My RF Frequency source is 32MHZ TCXO which has +- 0.1 PPM Frequency offset for +-5 percent change of TCXO supply voltage.
But , my question is regarding the Synthesizer inside the STM32WLE5 - Does changing the one of the power supplies for the STM32WLE5 device has influence on the Synthesizer output frequency ?
Thanks,
Viola
Uwe Bonnes
Chief
Oct 28, 2024 9:03 PM UTC
I am quit sure, the synthesizer in effect is digital and there is no effective drift with voltage beside the drift of the input clock.
