Feb 25, 2025 3:51 PM UTC
[STM32WL55JC1] - How to migrate from LoRaWAN EndNode to LoRa FUOTA example?
I have developed a LoRa application based on the LoRaWAN EndNode example, with some custom code and using the .ioc configuration. I am working on the Nucleo board STM32WL55JC1.
Now, I would like to migrate my application to the LoRa End Node FUOTA example while keeping my existing development. However, I am unsure about the best approach to achieve this.
Should I replace the LoRa End Node project inside the FUOTA example (though I assume I will miss some FUOTA-specific classes and functions)?
Or should I integrate the additional FUOTA-related projects (KMS_blob, EWARM,BFU, SECoreBin,Linker ...) around my existing LoRa application?
Any guidance or best practices would be greatly appreciated.
Thanks!
STTwo-32
Mar 24, 2025 3:13 PM UTC
Hello @SamyHaouaraUTC
What I suggest you is to try the same implementation as on the example LoRaWAN_FUOTA available under STM32Cube_FW_WL_V1.3.1\Projects\NUCLEO-WL55JC\Applications.
Best Regards.
STTwo-32
