mmontecchi
Mar 13, 2024 6:01 PM UTC
STM32WL55JC and LoRa
I have a project based on MIPOT 32001506xxx radio module.
The 32001506xxx is a multi-protocol sub-GHz radio module based on STM32WL55JC microcontroller.
I need an example to follow to help me use the radio module as a "simple" LoRa modem.
Thanks in advance
STTwo-32
STTwo-32Best answer
Mar 13, 2024 6:58 PM UTC
Take a look at this example.
Best Regards.
STTwo-32
STTwo-32
Mar 13, 2024 6:16 PM UTC
Hello @mmontecchi and welcome to the ST Community :smiling_face_with_smiling_eyes:.
If you are looking to implement a P2P communication between to STM32WL, i suggest you to refer to those examples. If you are looking for a end node to Gateway communication, you can use those examples.
Best Regards.
STTwo-32
mmontecchi
Mar 13, 2024 6:44 PM UTC
Thanks @STTwo-32 , I'm looking to implement a P2P communication between 2 STM32WL. I'm confused about the examples you linked to me. There is a description about it ? Which of them is right for P2P using AT command ?
Best Regards.
mmontecchi
STTwo-32
STTwo-32Best answer
Best Regards.
STTwo-32
mmontecchi
Mar 21, 2024 4:23 PM UTC
Hi @STTwo-32 ,
I take a look at the example you suggested, but it's only a little test (for example I cannot send a specific payload ). Viceversa for LoRaWAN and Sigfox the Application are complete (from the functional point of view).
Do you have an Application more complete for LoRa P2P ?
STTwo-32
Apr 8, 2024 3:21 PM UTC
Hello @mmontecchi
In the proposed example, you can control the payload and his dimension in the  subghz_phy_app.c and subghz_phy_app.h.
Best Regards.
STTwo-32
