Explorer
Apr 25, 2026 1:28 AM UTC
STM32WL55 output RFO_H output impedance
I am using a STM32WL55 UFQFPN48 in an application. I am only using the high power output (up to +22 dBm) and only plan on transmitting with this device.
I want to transmit in the 420-440 MHz range, but there does not seem to be any load-pull analysis data from within AN5457 which would give output impedance at this frequency. I can only find data for higher bands.
Is this data found somewhere else? I would like to use it for simulation and calculation.
Best
Saverio GRUTTA
Saverio GRUTTABest answer
Apr 27, 2026 7:00 AM UTC
I can provide the optimum load for 490 MHz at 22 dBm.
Zopt = 14+ j10
P_level (dBm) = 22 dBm
Pout = 21.9 dBm
IBAT = 108.5 mA
Best regards
Saverio
​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
Saverio GRUTTA
Zopt = 14+ j10
Pout = 21.9 dBm
IBAT = 108.5 mA
Best regards
Saverio
