Oct 24, 2025 9:43 AM UTC
STM32WL55 internal Pull-down Tolerance
Hello team,
We are using STM32WL55 MCU. I haven't found any information about resistance value of its internal pull-down resistance.
As far as I know it is typically 40k. But could you tell what is the tolerance of this value?
Best regards,
Vladislav
mƎALLEm
mƎALLEmBest answer
Oct 24, 2025 9:46 AM UTC
Hello @mokluza and welcome to the community,
Min: 25K, Max 55k
From the datasheet:
mƎALLEm
mƎALLEmBest answer
Min: 25K, Max 55k
From the datasheet:
mokluzaAuthor
Oct 24, 2025 9:50 AM UTC
Hello mƎALLEm,
Thank you for the quick reply.
Unfortunately your datasheet link doesn't work for me. Could you send me direct link or the file?
Ozone
Principal
Oct 24, 2025 9:57 AM UTC
The link is fine.
Probably a proxy issue on your side.
