Jun 12, 2025 4:39 PM UTC
STM32WL33xx: How to increase the wakeup radio distance?
What settings can be changed in LPAWUR_WakeupRadio_Rx code to increase the wakeup radio distance?
From data sheet ,  The STM32WL33xx RF output power can be programmed to deliver up to +20 dBm, in TX+TXHP mode, and in MRSUBG_WakeupRadio_Tx code,
MRSUBG_RadioInitStruct.outputPower = 20;
MRSUBG_RadioInitStruct.PADrvMode = PPA_DRV_TX_TX_HP;
The above changing is for TX side, what about RX side?
STTwo-32
Aug 1, 2025 9:45 AM UTC
Hello @Gwo
We have already implemented the optimal settings in the MX_LPAWUR_Init() function of the LPAWUR_WakeupRadio_Rx project. You can potentially increase the Tx output power, improve the matching network, or select a high-efficiency antenna.
Best Regards.
STTwo-32
