Oct 25, 2024 2:04 AM UTC
STM32WL33 can't go into sleep mode with freeRTOS
Dear Sir,
    I use wl33 mcu with rtos, but when I set to  stop mode, It didn't success.
   Is there a freertos examle?
    If I want to sleep with freertos in IDLE task , how can I achieve?
STTwo-32
Oct 31, 2024 6:06 PM UTC
Hello @SQ_it
The STM32CubeWL3 will be available soon with multiple examples and projects. You may find the example that you are looking for or find an example that may help you with some modifications to do what you want.
Best Regards.
STTwo-32
SQ_itAuthor
Nov 2, 2024 4:01 AM UTC
 I found the radio will refuse to go sleep.   Is there a freertos sleep and wakeup  example  soon?
STTwo-32
Dec 2, 2024 3:20 PM UTC
Hello @SQ_it
There is not such an example yet. You should do it on your own.
Best Regards.
STTwo-32
