RFric.1
Jul 13, 2021 6:31 AM UTC
STM32WL LoraWan_End_Node example, change payload to send to TTN
I have the STM32WL LoraWan_End_Node example working, but I don't understand the code with UTIL_SEQ_Run(UTIL_SEQ_DEFAULT); Where can I change the payload to send an ADC value to TTN?
YBOUV.1
YBOUV.1Best answer
Jul 16, 2021 12:48 PM UTC
Hi @RFric.1​ ,
The sequencer is nothing else than a packaged while loop. Please have a look at
https://github.com/STMicroelectronics/STM32CubeWL/issues/14
Basically you should not have to touch to UTIL_SEQ_Run(UTIL_SEQ_DEFAULT). It just checks if there any task or event to process, otherwise it goes to idle and calls UTIL_SEQ_Idle()
for the ADC value, that you want to send, you should modify the function SendTxData in lora_app.c and add (or replace) for exemple AppData.Buffer[i++]=YourAdcValue;
YBOUV.1
YBOUV.1Best answer
Hi @RFric.1​ ,
