Jan 14, 2026 1:04 PM UTC
STM32WBA5MMG pinout and pin description.
Dear Team,
I am using STM32WBA5MMG in my project. The datasheet does not contain pin description and their alternate functions.
I also checked STM32WBA5xxx datasheet (DS14127). It does not contain any pin description and alternate functions of STM32WBA5MMG.
For finding the pin details of , may I know where I need to check in the datasheet.
HARIOM
mƎALLEm
mƎALLEmBest answer
Jan 14, 2026 2:42 PM UTC
According to the module datasheet:
And according to the MCU datasheet WBA55UG means:
So yes it's a UFBGA59 package with 1MB of Flash:
mƎALLEm
Jan 14, 2026 1:29 PM UTC
From the DS14127 link: https://www.st.com/resource/en/datasheet/stm32wba52ce.pdf
I can see the pin description (Table 24):
What document link you are referring to?
PS: xxSMPS pins are supply pins and not GPIOs.
HariomAuthor
Jan 14, 2026 1:38 PM UTC
Thank you very much.
In that document which one corresponds to STM32WBA5MMG. I am using the STM32WBA5MMG Module. This is an LGA package.
mƎALLEm
Jan 14, 2026 1:52 PM UTC
The datasheet is for the microcontroller but STM32WBA5MMG is a module:
STM32WBA5MMG datasheet: https://www.st.com/resource/ja/datasheet/stm32wba5mmg.pdf
This is the module pinout, normally each pin has the same alternate functions as described in the MCU datasheet.
