Nov 20, 2026 9:15 AM UTC
STM32WBA55 — Peripheral-only BLE Link Layer with LE Coded extended advertising
We are developing an STM32WBA55 application using Zephyr's BLE Host with the following ST Controller Only libraries:
  • stm32wba_ble_stack_llo.a
  • LinkLayer_BLE_Basic_Plus_V3_0.a
Our application only operates as a BLE Peripheral. We require:
  • LE Coded PHY extended advertising
  • Peripheral connections
  • LE Secure Connections, encryption and bonding
  • Data Length Extension
  • BLE firmware updates over GATT
We do not require Central role, scanning or initiating connections.
The existing Peripheral Only library appears significantly smaller than BASIC_PLUS but does not support extended advertising.
Is there a supported Peripheral Only Link Layer variant that retains LE Coded PHY extended advertising for STM32WBA55?
Alternatively, is it possible to obtain a custom or optimized BASIC_PLUS controller library with Central, scanning and initiating functionality excluded?
Our objective is to reduce FLASH usage while retaining compatibility with Zephyr's Controller Only HCI integration.
Thank you.
