Sep 20, 2024 7:23 AM UTC
STM32WBA52 ADC DMA
I'm having some trouble using adc with dma and HAL. I noticed that in function HAL_ADC_Start_DMA Length parameter is multiplied with 4. Shouldn't be 2 (16 bit data from adc)?
File stm32wbaxx_hal_adc.c line 1760 (checked with versions 1.2.0, 1.4.1)
Best regards
STTwo-32
STTwo-32Best answer
Feb 11, 2025 1:15 PM UTC
Hello @cvs_dk
The correction has been implemented on the V1.6.0 of the STM32CubeWBA. It will be released on the coming days.
Best Regards.
STTwo-32
STTwo-32
Oct 1, 2024 5:09 PM UTC
Hello @cvs_dk
Thank you for reporting this. It seems to be a regression on the driver this conversation should be depending on the data width (Word, Half-Word or Byte) you can check this on the driver of the STM32U5. I've escalated internally for correction on the coming releases of the driver (under internal ticket number 192738)
Best Regards.
STTwo-32
cvs_dkAuthor
Dec 2, 2024 10:11 AM UTC
Hello @STTwo-32
In latest Cube FW 1.5.0 above problem is still not solved. What is the status of internal ticket?
Best regards
STTwo-32
STTwo-32Best answer
Hello @cvs_dk
Best Regards.
STTwo-32
