STM32WB5x with FreeRTOS hangs in IdleTask
Using STM32Cube FW_WB V1.18.0 on STM32WB5MMG, and compiler IAR.
Config with Tickless idle and LPM_ENABLE
We have an application that is using osDelay() and finding that the idle task hangs here,
Line 3478: configASSERT( xNextTaskUnblockTime >= xTickCount );
With values 10 and 13 respectively.
We have set the LPM to only use Sleep mode while we are booting the system. Using,
UTIL_LPM_SetStopMode( flgs, UTIL_LPM_DISABLE );
Any ideas why this might be?
