SWenn.1
Senior III
Oct 24, 2024 4:29 PM UTC
STM32WB5MMGH6 Project?
Hello.
I have done a few projects in the past with the above module and am currently working on a motor controller project using an X-NUCLEO-IHM03A and an NUCLEO-F401.  I want to know if the STM32WB5MMHG6 has enough room and power to integrate the motor controller application into the STM32WB5MMHG6 M4 core ?  Has anyone done this or can anyone point me to information regarding this?
STTwo-32
STTwo-32Best answer
Nov 19, 2024 4:20 PM UTC
Hello @SWenn.1
The capability to use a STM32WB on a motor control project may depend on the application characteristics. There is an example demonstrating how to spin a gimbal motor using STM32WB55 and ST's MCSDK v6 sensorless six-step algorithm: WB55Gimbal-6steps
So, this should be possible depending on the application. You may can give more details on your application and create a new post on the motor control forum to view the if it is possible or not.
Best Regards.
STTwo-32
STTwo-32
STTwo-32Best answer
Hello @SWenn.1
Best Regards.
STTwo-32
