stm32wb5mmg standby BUG?
Regarding the standby mode of the STM32WB5MMG, I have enabled only the RTC wake-up as trigger to wake up every second.
However, occasionally it freezes in standby mode, and after a watchdog reset, it doesn't even perform initialization processes.
Finally, it does not work until I manually turn the power off and on again.
Do you know any workaround for this freezing issue?
