stm32wb55rg bondding issue
1. Issue: When connecting a PC to a device for the first time, disconnecting the connection after turning off the device's power, and then turning on the device's power, the PC and device should automatically reconnect, but they are not connecting.
Problem: When initially connecting a PC to a device, disconnecting the connection after turning off the device's power, and subsequently turning on the device's power, the PC and device fail to automatically reconnect.
2. Issue : How to remove a pin code
I have two questions. If anyone knows the solution, please answer. thank you
